  • How much fuel does it require to press open sixteen or thirty-two or however many valve springs per miles of driving? Why not utilize hydraulic valve lash mechanisms? Anyone remember the first modern auto line to incorporate hydraulic lifters? No fair GOOGLING this...
  • What advantage does the hydraulic valve lash mechanism have when referring to the fuel required to open the valves? All the hydraulic valve lash mechanism does is limit the need for manual valve clearance checks. Or were the two questions unrelated?
  • K Charles wrote:
    I would bet that electromagnetic valve actuation will end up being the winner.
    That's what I would bet- reason being the valve train can be put under direct control of the engine cpu.
  • So explain how this is going to improve my mileage and performance in a diesel engine that is governed to 2600 rpm? I do think the electromagnetic valve actuation will end up being the winner because you could program different timing like having a variable cam.
    Bill
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
