dougrainer
Apr 15, 2018Nomad
A Transfer switch is just 2 to 3 relay's, nothing fancy. The OP overloaded the system and the WEAKEST point failed. Which was the loose Neutral wire. The system generates extreme heat when overloaded and the Neutral burnt due to that heat. Your post is an excellent question that most people do NOT understand----Some assume that the FEED breaker will trip and save the burning or possible fire from overloading a circuit. NO always so and not so most of the time. One of the most common causes of failure of any RV transfer switch is running more amps than the feed circuit can supply. The Heat build up causes the relay's to fail. Doug
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
