jwjkswanson
Jul 14, 2013Explorer
OK, here we go.
The manual you gave me is the same one I have and I am working my way through the troubleshooting portion.
I found the fuse and you are right they do not look like fuses. I checked them with a volt meter to determine if there was resistance and there was so we are all good there.
In addition, I topped off the oil in the reservoir, so all good there.
Now I am on to the next item to check, that is the solenoids.
On page 16, it shows there is a solenoid somewhere between the positive side of the battery and the control pump. My first question is, do you happen to know where that solenoid might be in relation to either the battery or the pump??
Secondly, if and when I find it, I will need to change it out. Any thoughts or ideas on doing that?? Tricks, tips, etc.
Thanks again to all who have looked.
TTYS.
Jimbo
TTYS.
Jimbo
