Slownsy's avatar
Slownsy
Powering a electric winch
My 2015 F350 diesel comes with 2 batteries, not sure how they are connected, so to connect winch to only 1 or run cable to both? Max draw about 400A.What says the gurus.
Frank.
  • rhagfo's avatar
    rhagfo
    Explorer III
    MEXICOWANDERER wrote:
    00 Cable is fine. The group 65 batteries are paralleled from the factory. Ford does not provide a big enough cable to the frame for ground. You'll have to make your own.
    Finally a correct answer! Diesels require more cranking power. They have two 12 volt batteries connected in parallel. You only need to connect to one set of terminals.
  • 00 Cable is fine. The group 65 batteries are paralleled from the factory. Ford does not provide a big enough cable to the frame for ground. You'll have to make your own.
  • 2 6V batteries configured for 12V or 2 12V setup for 12V?
    If 2 6's you MUST use both to power the 12V winch (an assumption). If 2 12V you "could" wire to only one battery but that would still not be the recommended setup.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
