S_Davis
Jul 04, 2020Explorer
2oldman wrote:S Davis wrote:The voltage will rise, slowly, as the batteries charge, until the absorb setting is reached.
The powermax is only putting out about 13 amps @ 12.68 volts, does this sound right for a 75 amp charger?
Yes I have set the voltage, the first time I set it to 14.82 The Trojan spec but was only getting 14.68 when hooked up and charging. I reset it to 14.96 to get 14.82 out when charging, it just seems the amp output is low.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
