BFL13
Jul 04, 2020Explorer II
Good that it is 14.68 :) so see my note above re the 13 amps.
You can run more 12v loads as a test. If the battery is still accepting 13 amps on the battery monitor, and those loads are running ok, then the converter must be putting out more than 13 amps which the loads are using.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
