S_Davis
Jul 04, 2020Explorer
BFL13 wrote:
Good that it is 14.68 :) so see my note above re the 13 amps.
You can run more 12v loads as a test. If the battery is still accepting 13 amps on the battery monitor, and those loads are running ok, then the converter must be putting out more than 13 amps which the loads are using.
There are no loads on the bank when charging and I am using fluke digital meters for my volt and amp values. Maybe you are right and the batteries were at a higher state of charge, I was going by the Trojan specs. I will get a meter and check specific gravity.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
