BFL13
Jul 04, 2020Explorer II
time2roll wrote:
13 amps is fine if you have 14.68 volts. This is why I recommend a smaller PowerMax with just two batteries. 35 amp would be fine.
That's if you don't mind another hour of gen time to do a 50-90 per my ugly graph above. And if the campground gen hours let you. Of course on shore power you don't care about the time it takes.
Then there is the dreaded 20% charging rate in Bulk for AGMs so a 35 amper being 20% means the bank is 175AH or less. The OP does not have AGMs though.
I did find that low and slow was how to recharge Marine/RV batts to true full, which don't like a high charging rate. But you have to maintain the low amps and keep charging till they reach 16v. Now the hydrometer says you are there and can drop to float. No wonder people have poor luck with those things using a 14.4v converter :(
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
