opnspaces
Sep 11, 2019Navigator III
DSchmidt_2000 wrote:
I already own a Yamaha EF2000is but it struggles to start our fridge and/or freezer in eco mode.
Because of lawsuits, Edison is saying they could turn power off for days when it's dry and windy out. Figure I should get ready.
Thanks
By your post about Edison shutting off power I'm assuming you're talking your household refrigerator and freezer. While it never hurts to be prepared that really sounds like nothing more than a lot of sabre rattling by the utility.
Something doesn't sound right about your appliances. My EU2000i stays in ECO mode and powers up my refrigerator, chest freezer, household lights, and a computer or two. When a compressor kicks in the RPM's increase, but nowhere near full throttle. But then again my situation is going to be different than yours.
But as to your question, you might do some experimenting before you buy anything new.
For example, does the current generator struggle to start only the refrigerator or freezer singly? Or are both units trying to start at the same time and adding a bunch more load? Normally the compressors will not cycle on simultaneously, except for maybe the first time you plug them in after the power goes out. So if the generator can manage each unit individually; Then plug in the refrigerator and when the compressor turns off and the RPM's drop then plug in the freezer. After that just leave both units plugged in and they will usually cycle at different times.
If your generator still struggles on a single appliance you might want to consider the age of the appliances before you consider a new generator.
How are you powering the house? Are you using a transfer box, or suicide cable to power the house? Or are you running individual extension cords to the critical loads only?
As far as the Predator, no I don't have any experience or videos. But it is a Harbor Freight product and I would not be surprised if your Yamaha 2000 outperforms the 3500 Predator. Even if the Predator is stronger, I would keep the Yamaha fueled and ready as a backup in case the Predator dies.
