DSchmidt_2000
Sep 11, 2019Explorer
Thanks everyone for your feedback! I'll start scouring for a coupon for the Predator 3500.
With the lawsuits and the damage from the Thomas and the Camp Fire (which also killed a lot of people) I don't think they're bluffing. This past weekend they did in fact shut down power due to high winds up above Santa Barbara.
My testing was done back when I first got the Yamaha. My takeaway then when comparing to other peoples experiences with the Honda was that I should have gotten the Honda for its better surge capability.
Fridge is 1997 vintage. I used a 25' 12ga extension cable for my testing. From memory (I need to repeat this as the testing was many years ago) with only the fridge connected to the generator, and after letting the head pressure equalize, the startup time in eco mode was 2-3 seconds. With only the freezer connected (2005 vintage), while in the eco mode the startup time was so long that the thermal overcurrent breaker tripped on the freezer before completing. That freezer compressor uses a PTC starter - the start field gets weaker with time as the PTC heats up. So if it doesn't start quickly, it won't. In non-eco mode things are better but I wouldn't trust them together, especially the freezer with that PTC starter.
I own the Yamaha EF2000is, a Wen 56200 and a Pulsar 2000W inverter. The Wen has the best surge capability of the three. The Pulsar and the Yamaha are a close tie.
This past weekend I paralleled the Pulsar and the Wen and together in eco mode they effortlessly started my 1HP air compressor (being used as a test motor load). Singly, the Pulsar won't start the compressor even in non-eco mode. The Wen will start the compressor in non-eco mode but only if the starting pressure is zero. The Yamaha, like the Pulsar, won't start the compressor in eco mode or not.
The Yamaha will be sold soon. Yamaha's selling point of the fuel gauge is gone as mine doesn't work anymore - something swelled in the mechanism so it's jammed. The poor surge capability too makes me not want it. Figure I can sell it and put the $$ towards the Predator to leave at the house.
opnspaces wrote:
By your post about Edison shutting off power I'm assuming you're talking your household refrigerator and freezer. While it never hurts to be prepared that really sounds like nothing more than a lot of sabre rattling by the utility.
does the current generator struggle to start only the refrigerator or freezer singly?
If your generator still struggles on a single appliance you might want to consider the age of the appliances before you consider a new generator.
How are you powering the house? Are you using a transfer box, or suicide cable to power the house? Or are you running individual extension cords to the critical loads only?
As far as the Predator, no I don't have any experience or videos. But it is a Harbor Freight product and I would not be surprised if your Yamaha 2000 outperforms the 3500 Predator. Even if the Predator is stronger, I would keep the Yamaha fueled and ready as a backup in case the Predator dies.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 21, 2026
