Route_66_Travel's avatar
Jan 18, 2019
Predator 3500 Question
Before I ask my question, I will say I did do a search and couldn't find the answer. I have been using a Predator 3500 to power my RV for some time now and have no complaints. I do not use my Progressive EMS because it detects an open ground, which I understand. After watching some YouTube videos I decided to make a bonding plug so that I could use my EMS.
Using my voltmeter I measured the voltage from ground to either side of the 120 volt outlet and found it to be 60 volts on either side. My question is what side do I wire to ground? The videos all seem to show 120 volts on one side and zero on the other. I am confused because I thought I would see 120 volts on the hot side, which is usually the right side of the plug, and zero on the left, or neutral side. I assume to make a bonding plug I would jumper between the left side of the socket to ground. But since I see 60 volts on the left side of the socket I need to be sure I am not going to damage my generator, hence the question.
Thanks for the help in advance.
  • at one time it was common practice to solder wire connections and then tape them, instead of using wire nuts, the last and only time i did this was on one government subsidized housing complex 46yrs ago
    Is this what your talking about?
    I recently did a bunch of electrical repairs on a house that was probably built in the late 50's or early 60's. It had connections I had never seen before. They had stripped the wire in the middle of its insulation and twisted & soldered another wire to it. After this odd splice, there was a bit of insulation and then the wire was stripped again and connected to the switch or outlet. The "splice" was wrapped with electrical tape. AT first I thought this was a home-owner hack but I found them all over the house and in area's I don't believe anyone had ventured.
    It was strange but sound. Never the less, any time I had to work in one of those junction boxes, I brought it up to modern specs.
  • good soldered connections DON"T fail
    but making all those soldered connections and putting in all those switches and outlets is a slow process
    i think if you compare the size of the room too the number of outlets
    you will find a lot fewer outlets in those old houses with soldered connections
    when NEC was changed to demand more outlets per wall length
    the industry invented the wirenuts to allow for faster & easier construction processes
    JMHO
  • Yeah, I noticed they often had only one outlet per wall, even if it was 16' or more long. I added new outlets in some of those locations where they had a specific need.
  • When my brother built his house he connected the grounds together using a crimp sleeve which is an approved method. Since he is an electronics technician he filled all the crimp sleeves with solder making a super nice job. When the inspector came out he was forced to cut out all those connections and splice again without solder. Stupid rules!
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
