Boomerweps
Aug 26, 2023Explorer
I finally figured out the generator name to power relationship. The model number is the peak power rating and the continuous power rating is 400 watts lower on the average.
Example: Honda EU2000 has a 1600 watt continuous rating. My new in the box Champion 1800 has a 1400 watt rating (bought for paralleling).
After further study, I’ve learned that when two different rated inverter generators are paralleled, the bigger generator is limited to the lesser generator’s output. They try to equalize the load. While the bigger one tries to pull its half the load at higher values, the lesser one will shut down from overload, causing the remaining one to also shut down.
I.e., when paralleling a 3600 and a 2000 watt continuous rated generators, you’ll only get 4000 watts output. Hence the manufacturers ALL stating you should use the same make and model when paralleling (aside from selling THIER product).
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
