valhalla360
Aug 30, 2023Navigator
jimh406 wrote:valhalla360 wrote:jimh406 wrote:
Based on what I've seen on YouTube, buy the extended warranty. That being said, I don't have a standalone generator. Also, they are a bit louder than a Honda or Yamaha, but they do cost A HECK OF A LOT less.
Fixed that for you.
We went with a Champion 4500w to replace our Yamaha 2400w. Even though it's not the fancy name, it's actually quieter because the smaller 2400w unit was running at about 3/4 throttle with the air/con running while the 4500w unit is at around 1/4 throttle.
Not really, you seemed to buy a Champion which is not a Predator. ;)
Fwiw, I haven't run across Champions with issues, but that's not the same as saying they don't have them.
Pick a brand...once you get past Honda & Yamaha, they are ALL A HECK OF A LOT CHEAPER. Generally at least half the cost and the modern knock offs are generally pretty good machines. Most of the complaints you see on youtube are from honda aficionados trying to justify the high prices.
We bought he Yamaha because at the time it was Honda or Yamaha if you wanted inverter. We got rid of it because it had issues. First shop couldn't fix it. Tried a second shop and with the cost of parts it was cheaper to buy the new Champion which was larger and had more features (both were yamaha affiliated)...don't buy the myth that "red" or "blue" are immune to problems.
