DiskDoctr
Jun 15, 2017Explorer
Chris Bryant wrote:
First remove the electrode, wipe the ceramic down with rag soaked in spray silicone, lightly sand the wire tip and reinstall- 3/16" gap, centered.
I used to replace them all the time, then I found just cleaning does fine.
Thanks, Chris. That may be it. I pulled the connector and used a screwdriver like testing spark plugs. It zapped, I zapped, it lit, LOL.
Although it's possible the plug connection was not making good contact, I think it's more likely corrosion is on the ignitor or the burner.
So for now the fridge is working and reignited each of several tests.
THANKS!! :)
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 26, 2026
