N-Trouble
Apr 07, 2015Explorer
Clay L wrote:
One thing not mentioned is that the output psi is not the only important specification. Flow rate is very important. A smaller orifice will increase psi but that reduces flow so when comparing units look for a high flow rate and a high psi.
Very true. You can force a high PSI through a pinhole but it's going to take a LONG time to get the job done compared to a similar PSI unit with much higher flow rates. This is typically where electric units fall short. Too many focus on PSI alone when shopping
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
