wa8yxm
Oct 10, 2018Explorer III
Takes both time and COLD to freeze. I mean it is not like
35, 34, 33, ICE, 31 more like 5,4,3,2,1,0, and an hour later ICE.
Some of this depends on the construction of your trailer.
IF the tanks are fully enclosed (DO NOT FORGET THE WASTE TANKS AND LINES WHICH ON A TRAILER ALMOST ARE ALWAYS EXPOSED) you can sometimes put additional HEAT in the lines... I have been down to 11 degrees w/o damage by adding a string of C-9 Christmas tree lamps (About 270 watts) under my fresh tank and a 100 watt rough service lamp (Caged. Like A Tunnel lamp) in the waste end of the bay. I also added a 150 watt heater that night. Park .. Well one building was totaled and the park had to be fully re-plumbed cause it was not designed for 11 degrees but I survived with no damage. one line froze but PEX can survive that. (Heat at both ends)
Heat tape on the exposed pipes
You can get peel and stick "Panels" that heat up the tanks as well if you can access.
Though I think they are a bit pricey.
Several other options.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
