time2roll
Oct 10, 2018Nomad
swimmer_spe wrote:Add heat or drain the water out of the lines is really the only option. Zero to 60 psi will not significantly affect freezing.
I plan on using my trailer well into November. I want to still use the water system without a burst pipe.
Typically, it does get a little below freezing. Besides draining the lines, or keeping the furnace going 24/7, how can I reduce the chances of ice forming in the lines?
Would it be better if the lines were under pressure or not?
In short, I don't want to winterize the water lines yet, nor do I wan a burst pipe.
Indoor storage is probably the best option.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
