swimmer_spe's avatar
swimmer_spe
Preventing freezing pipes during the shoulder season
I plan on using my trailer well into November. I want to still use the water system without a burst pipe.
Typically, it does get a little below freezing. Besides draining the lines, or keeping the furnace going 24/7, how can I reduce the chances of ice forming in the lines?
Would it be better if the lines were under pressure or not?
In short, I don't want to winterize the water lines yet, nor do I wan a burst pipe.
  • Hi,
    Replace the return air grill for the furnace with a twin window fan. I have mine on a thermostat at the water pump. It draw a scant 27 watts so is easily run on an inverter.
