westend
May 10, 2016Explorer
All of the RV portable sets that I see Aamp sell have the controller mounted on the back of the modules. I would bet that what you have is the female connector and the wiring to the battery.
Zamp's typical wiring accessory looks to be a UV resistant pair of AWG 12 wires and a pair of alligator clips. I'm sure the SAE connector is available, too.
I'd suggest that if you are thinking about getting useful solar power that you locate the controller close to batteries and forgo using the OEM wiring. If you only use a portable 60W panel or so, the OEM connection should suffice. You could look at the wiring at the battery terminals and ascertain just what size wire is used.
