The feature I like most on the MS is three different lengths of absorption time based on battery start voltage. This gives a short boost in storage, couple hours in normal use, or all day absorption if you run the battery super low overnight. Time is adjustable to the minute, voltage to two decimal places.
Also equalization (if used) can be every day or 300+ days if you choose. Counts selected days to remind you to check the water. Logs 20+ data points. Can be network connected to send info as requested.
Ecoworthy does not compare on any of this.
