KMLsquared wrote:
BFL, could you expand on why you would prefer the PWM? I was beginning to lean towards MPPT due do the fact I camp all year around northern ca and I want to flat mount panels on the roof. I have gathered that the MPPT works better in less than optimal panel aiming conditions. Am I way off base?
My situation is different from that so I don't know what would be better for that.
I had two 12s last year with PWM and got the panel's full amps so I was happy with that. Then this year I tried it with one 230w panel and MPPT thinking I would get more amps than with the PWM. I did in April-May when it was cool, but by June it was warmer and now I was getting fewer amps with the MPPT than I would have with PWM. Turns out that panel heating loses voltage so you get fewer amps the way MPPT works. With PWM you don't get that reduction in amps with hotter panels. Difference was PWM 14.5a, MPPT cool 15.5a, hot 13.5a
So on average I would do better with a steady 14.5 instead of mostly 13.5 for the time and location we use solar. However there are many other factors in what to chose like price, roof real estate, etc etc.
Man-handling as portables another thing.
As it is, we have enough solar anyway even with the 13.5 so it is no big deal for getting by or not, and it was less money for the 24v and MPPT in this case than the more expensive 12v panels would be, thanks to the MPPT controller only costing $102 instead of $300 or whatever.
I don't know about that low/indirect light advantage for MPPT. Haven't noticed it but others swear by it. I do aim my panel during the day, if that makes any difference.
