MEXICOWANDERER
Nov 17, 2014Explorer
I can surface charge a battery to 13.4 volts. If voltage is used as a parameter to mistakenly determine level of charge, when a perfect battery loses the charge and settles into a 100.00000% level of charge of 12.7 volts, seemingly SEVEN TENTHS of a volt is "lost". I have seen overcharged batteries show 13.8 volts or more when freshly disconnected from a charging source. Just because the voltage level decreases to resting voltage does not mean it is losing capacity fullness.
This is a perfect example of how and why abstract charge measurements are so invalid. When the hydrometer says the battery acid density is 100.00000% it is telling you the truth. If you start out your voyage and the hydrometer shows 1.280 density and arrive at your destination with half a volt less, but still showing cell density at 1.280 the batteries have "lost" nothing. If density drops to say 1.275 then start looking for a charging problem.
This is fundamental battery and charging analysis. If you choose to ignore it, then may the force be with you...
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
