MEXICOWANDERER
Nov 17, 2014Explorer
It's the meter that is schizophrenic if it disagrees with specific gravity, and you've satisfied yourself with discrete component testing. Verifying the accuracy of an amp hour meter on a cruising sailboat is a challenge. The saving grace there is battery banks are so huge, extracting 1 kWh does not lead to a huge change in resting voltage, so a 16 or 24 ampere incandescent light bulb test (amperes X hours) proves to be quite valid. I uncovered a disturbing number of instruments with 5.0% or greater ampere hour error. This gets hysterically complicated when batteries are VRB, sealed, and precludes the use of a hydrometer. This is where an extremely precise shunt and meter are required.
http://www.farnell.com/datasheets/67361.pdf
I do not trust a regular panel meter. I use a 4-1/2 digit digital multimeter to establish voltage drop across the shunt. Amperage measurement accuracy is amazing (AAA)
Shunt NERD FOOD (PDF) Link To National Institute of Standards & Technology paper
http://www.nist.gov/calibrations/upload/single-range-current-shunt.pdf
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
