time2roll
Aug 23, 2017Nomad
ctwebb wrote:Monitor the voltage on this leg as the A/C starts. Not sure what the cut-off would be but the relay will drop out if voltage does sag too much.
now it sounds like the Transfer switch is opening when starting the second unit.
Try swapping the air conditioners each to the other side of the breaker panel. This will help determine if you have a problem A/C or if you have a wiring issue.
Check the transfer switch sensor wire is connected to the side where the A/C actually runs. s/b on the 30 amp side.
Could temporarily bypass the transfer switch.
Could wire the transfer switch to have the NC side on the generator but that would not be the preferred position.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
