GoBoy45's avatar
GoBoy45
Problem with Airhorn on Smartwheel
Bar across bottom of Smartwheel is "sticking" & airhorn will not stop until I turn off horn master rocker switch. I've removed the screws under the wheel but can not remove the "bar" from steering wheel!
Any ideas??
Thanks
    Any ideas??
    Thanks
    It might help you to remove the center pad which is directly above the horn bar. There is an access hole on the bottom of the wheel where you can insert an Allen wrench to remove the pad. I believe it's 5 mm.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 14, 2026
