Crambo's avatar
Crambo
Problem with Champion generator
I bought a new champion 2000 watt inverter generator a couple of weeks ago and it worked great these past two weekends. I went out earlier to winterize my TT so I fired it up and plugged in my trailer. Everything ran fine for a couple of minutes and the generator shut off all of a sudden. I fired it back up and it ran for a few seconds and shut off again. I unplugged it and hooked up my old generator to finish winterizing and all of a sudden the trailer lights went dim and the carbon monoxide detector showed a fault by flashing red and green. I shut everything down and the detector reset itself. I fired up my old generator again and everything worked normally. I finished winterizing my trailer it the brand new Champion gennie still won’t start. I’ve checked, gas, oil and pulled the spark plug to make sure it isn’t fouled. I’m at a loss now. Is there something else I should check before I call Champion and if I have to call, how is their customer service?
  • DarkSkySeeker wrote:
    My Honda behaves as you describe when I fail to open the vent on the filler cap.
    I thought that too but it showed to be in the proper position. I’m going to go check it again though to be sure. It was getting dark outside and my eyesight isn’t what it used to be.
  • Love my Champion but with all products there is always an issue every now and then. I would call customer service. I had to call them before to get a replacement part and I have to say they had the best customer service I have ever dealt with. Good luck!!!!
Having RV issues? Connect with others who have been in your shoes.24,324 PostsLatest Activity: Oct 05, 2025
