yankee_camper's avatar
Aug 03, 2013
Problem with converter fuse panel
I have a barely 2 year old PD4645 converter with the red led indicator lights on the 12v fuse panel that light up when a fuse is blown or pulled from the buss.The problem I have run into is that the indicator lights have stopped working. Found this out the hard way when last week end I blew the fuse for my range hood fan/light while working on it. Went crazy trying to figure out the problem because I foolishly never checked the fuse (no indicator light came on). Finally physically checked all the fuses and found the problem. Until this happened the board and lights worked flawlessly ,now only the #4 & #9 circuits will illuminate when pulled. Anybody got ideas or suggestions?
I've called Progressive Dynamics all the techs where out and gave Randy at best converter a call, and even he was scratching his head. The indicator lights themselves aren't burnt out cause I can jump them to light them up.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
