- old_guyExplorertry traveling without the frig on, it will be safer for you and everyone on the road with you. put small reusable ice packs in around the food and you will still have cold food.
- Reddog1Explorer IIMoved from Truck Campers
Wayne
Moderator - lap527ExplorerSoooo familiar.....soooo frustrating....sooooo not right. :h Sorry we both have the same problem. Still trying to figure ours out!
- 2oldmanExplorer II
djg wrote:
Pilot lights don't light themselves.
Don't know it is electronic ignition so when you stop it must relight itself - IvylogExplorer IIISounds like the flame is blowing out when moving. Try wrapping some tin foil around the outside of the burner area to block the wind. Is there a plug in the end of the drain tube?
- harobertsonExplorerHave you checked the settings, auto vs manual on the fridge? If it goes out while you are traveling the flame may be going out. Are all the plates in their correct position? If it is a three way fridge, are you plugging in at night? Is there enough propane in the tank?
Good luck,
Harry - djgExplorerDon't know it is electronic ignition so when you stop it must relight itself because if I am stopped the fridge starts to cool down at night the other night it went from 50 to 32 in the morning then traveling it went up to 54
- jimh406Explorer IIIUnclear, but does it blow out?
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
