petendoll's avatar
petendoll
Problem with trailer brakes
Today I hooked up to my trailer. I checked to see that my brakes were working. Nothing.
I pulled the emergency pin to see it that operated them. Nothinig. I don't believe my problem is from the truck to the trailer plug. I have a new battery in the trailer that should have activated the brakes when the emergency pin was pulled.. Where do I start my search for the problem? Bad ground?
  • Check for loose or broken wires at the brake drums. If the manufacturer used wire nuts to tie the wires together make sure there's no corrosion at each connection.
  • Hold a compass down close to trailer brake drum ----lower area.....then have someone pull pin on emergency brake switch.
    Does compass needle deflect towards drum
    NO....then magnet is not being energized so wiring needs to be checked
    YES...then magnet is being energized and brakes need adujstment
Having RV issues? Connect with others who have been in your shoes.24,340 PostsLatest Activity: Nov 30, 2025
