bobbolotune's avatar
bobbolotune
Problem with U-Haul refill. Time replace my propane tanks?
My truck camper has 20 lb upright removable propane tanks. There are a few dings on the tanks with some minor rust in the ding. I needed propane while in Las Vegas and found a local U-Haul and she said that she shouldn’t fill it because of the ding. But she filled it anyway because she knew it would become an argument if she didn’t.
I saw the same thing on the U-Haul website that they won’t fill tanks with surface damage or if flaws have been painted over. Of course I can (and probably should) sand and paint over the dings, but that won’t help for U-Haul.
I have spent hours on google searches trying to understand if I need to replace these tanks. With no luck because it keeps popping up other topics. One thing that did pop up (and causes problems in the searches) is that the horizontal permanently installed tanks are much thicker so some rust isn’t a problem. But the 20 lb upright removable propane tanks are thinner, and it is unclear if U-Haul is being overly cautious or if a few dings actually are a problem.
Seems a new tank is around $30 each, plus I would need to find a place that knows how to purge the new tank. Also I am not clear if tanks for BBQs from a local store are good enough for RVs, or if you want a better quality.
I doubt if it is necessary to replace the tanks but it is a problem if I drive through a city (and city traffic) to a propane fill place and they refuse to fill the tank. On the interstate I fill up at Pilot / Flying J and they don’t question it. But off the interstate sometimes U-Haul is the easiest (or only) local option for tank refill, and if they give me a hard time that is a problem.
The tanks are 5 years old with a few dings. Is it time to replace the tanks?
  • Tvov's avatar
    Tvov
    Explorer II
    Yes. Pretty much any damage, and they have to be replaced according to whoever makes the regulations. As you found out, some places may still refill them just to make the customer happy.
    Is there a difference between "BBQ" propane tanks and "RV" propane tanks?
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
