dougrainer wrote:
wolfe10 wrote:
Do NOT attempt to run a refrigerator that has leaked its coolant.
It will NEVER cool again with that cooling unit and you could start a fire if you run it with an empty or leaking boiler.
Once the Ammonia is gone, there is NOTHING to catch fire. Doug
The NFPA has assigned a flammability rating of '1' (slight fire hazard) to ammonia
The hydrogen gas would be of more concern but it also dissipates almost immediately when leaked
Fire hazard, if any, is long gone after cooling unit leaks and thermofuse operated shutting down system
