opnspaces
Oct 01, 2014Navigator III
I would remove any water filter and then put bleach solution in everything including the water heater.
7/8 is usually the same socket size as 22mm. 24 mm is approximately 1 inch.
You might have the wrong drain plugs if they don't thread in.
I install my Atwood drain plug finger tight. Grab it with an old rag if needed to turn extra tight (with your fingers). I haven't had a problem with mine in 9 years.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
