RK_Hauler's avatar
RK_Hauler
Prodigy P3 Overload Warning
I am getting an intermittent overload warning on my P3 controller that just started about 500 miles ago during our last trip. I would like to get it resolved to get us back and then R&R the whole system.
The warning only happens after I come to a complete stop, then disappears when I let off and/or pump the brake. It doesn't show up until I come to a complete stop again. No warning when in the process of stopping so haven't lost brakes when stopping.
I suspect it is a magnet or a bad wire inside the drum and would like to test to see which one it is without removing drums. Wondering if anyone has advice on a good/best way to do this sort of test?
Thanks in advance,
Greg
  • Larry gave you good advice. The way most manufacturers run the wires is down one side and then through the axle to get to the other side. The inside of the axle is not smooth and over time vibration wears holes in the insulation. As the wires move the bare spot touches and shorts. This is a very common cause of intermittent issues.
  • Thanks to all for the good tips. The part that has me stumped is how to figure out which magnet/wheel is causing the problem. I did mess with the P3 diagnostic, but that measures amps on the whole system.
    I give the compass test a try first, but suspect all are working until the brake assembly on one of the wheels is torqued to engage the brake shoes against the drum. Then something gets shorted...a bare wire or a bad magnet. Then it quits when the brake is released.
    The only solution may be to cut the wires on one magnet at a time until the warning doesn't pop up going down the road. Would rather find an easy way to figure it out in the driveway though.
    Might be seeing a disk brake conversion in my future - sure tired of the drum brake problems.
  • Got a compass....a real hand held one
    Hold it down next to wheel where brake magnet is
    Then have someone apply trailer brakes via manual level on brake controller
    Watch for deflection of compass needle
    No deflection....magnet not energizing
  • You have a P3 use the diagnostics available. Set the P3 to indicate the current draw.
    Most 4 wheel trailers will draw about 1 amp for each volt applied.
    Monitor the current when you are stopping.
  • We had this problem in the summer of 2001 but before we were home it was good so on our 1st trip south for the winter it started again. over load and the short signal came on with the trailer brakes working or not working or really working. Wire going though the rear axle had a bare area and was shorting off and on depending on toad conditions plus on that axle a magnet was bad.
    Easy fix for the rv shop in Stockon ca.
    chevman
Having RV issues? Connect with others who have been in your shoes.24,318 PostsLatest Activity: Sep 14, 2025
