ernie1's avatar
ernie1
programing of Mercedes key fob
I have a 2018 PleasureWay XLMB that is built on a 2017 Sprinter chassis. Recently one of my key fobs quit working and the other works as it should. I've changed the batteries, cleaned the contacts and still cannot get it to work. I tried programing it from info I found online and key fob worked for a couple of days and then quit again.
I contacted a mobile locksmith that specializes in European vehicles and he brought a new key fob and cut a new key. But when he went to program the fob so that it would unlock the doors it simply would not program no matter how many ways he tried it. I was told that there are
two programs in this fob. One deals with the starting of the engine and this works fine and this is true on my old fob as well as the new one.The other program deals with the unlocking of the doors. Neither the old nor new fob will program to unlock the doors. After a couple hours of trying the locksmith gave up and left.
At this point am I stuck with having to bring the vehicle into a MB dealership for programing of the fob. Keep in mind that I still have one original key fob that works as it should so I'm thinking there's not a problem with the vehicle end of things.
  • I just got a fob for our 2018 RAM 2500. The locksmith had to order the fob, the he had a programming box about 12 inches by 10 inches with a screen. Took the original key put it in the ignition switch, plugged the box into the OBDII port and fiddled for 10 minutes before getting it programmed. Cost $228.
    No telling what the Dodge dealer would charge.
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
