IT_Burnout's avatar
IT_Burnout
Progresive Surge Protector Question
I have a EMS-PT50X surge protector, and it seems like it has a problem. When I plug it into any source (15A, 30A or 50A) from a campground or from my home it takes a long time to gate power through the unit. I have tested the outlets first with a meter to make sure they are hot and they seem to test good. I have had a couple instances where I never did get it to output any power. It always gives a readout of L1 and L2 with 121 +/- volts at 60hrz with 0 amps. I never see any type of error code on the unit at all. When it does work correctly I plug it in and wait a minute or 2 then I hear what sounds like a couple relays click in on the unit and things power up and it works good. I have tried this with the RV plugged in and without a load just a digital meter for a load and it’s the same. I have also tried it on 2 different 5th wheels and it acts the same. I didn’t notice this going on when I first got the surge protector this spring. But I will admit I am not always as observant as I should be. I did send an email today to Progressive to see what they had to say about it. Anyone else ever experience this?
Having RV issues? Connect with others who have been in your shoes.24,303 PostsLatest Activity: Aug 24, 2025
