DrewE
Sep 22, 2021Explorer III
The charge wizard basically "upshifts" based on time and "downshifts" based on voltage falling below certain thresholds, resetting the timer. It takes it about 30 hours (per the manual) to switch from normal to storage mode, and will go back to normal mode whenever the system (battery) voltage drops below some value, resetting the 30 hour timer. Similarly, there's a lower threshold to switch to boost mode, and a four hour timer to go from boost to normal mode.
I suspect it's working as designed. Normal mode at about 13.6V is pretty close to what older single-stage converters output all the time; several hours at that level aren't going to cause trouble for the batteries, though days upon days will cause their electrolyte level to drop noticeably.
My 9200 converter (I don't recall offhand if I got the 9245 or 9260) has been wholly satisfactory so far; it works quite well when left to its own devices, in my experience, and I top up the water levels once a year whether they need it or not.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
