1L243
Sep 23, 2021Explorer II
wa8yxm wrote:
What kind of battery monitor. The standard indicator on the wall of most RV's will always show "Full up" when plugged in, any "Volt meter" type indicator shows full up when plugged into shore power.
The current may also be different than what you think it is .
Give the Wiz at least a day to charge than read it. worked fine on mine.
I have a shunted battery monitor it shows power coming and going amp hours and percentage of charge. I also tested the voltage at the battery 13.6 volts but that is controlled by the converter while its plugged into shore power.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
