BFL13
Sep 24, 2021Explorer II
The PD 4hr timer is when you trigger boost with the CW, otherwise it does boost by itself if needed for as long as needed. Not sure what happens if the batts get near full before the 4 hrs is up when using the CW. From previous threads on this ISTR it thinks 97% SOC is "full" and it drops to "Normal". This showed up with Fisherguy's graphs.
scroll to the PD graph top of page 1 and then discussion about the 4 hrs.
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/24129716/gotomsg/24130417.cfm#24130417
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
