otrfun
Feb 11, 2014Explorer II
GaPete wrote:Ref the bonding plug. If you don't use one with your generator more than likely your PI EMS will return an E2 or Open Ground error and will not allow any power into your TT. You do have the option of turning off ALL EMS protection and allowing unprotected power to enter your TT from your generator rather than use the bonding plug.GaPete wrote:Based on Larryetc's post I think I see what you are talking about. A plug for gen recept with grd/neutral bonded????
OTRFUN.....what do you mean by bonding plug?
Thanks
The bonding plug I use is a dummy 110 volt plug with the neutral bonded/connected to the ground. I plug the dummy bonding plug into the vacant 110 plug on my generator before I power my TT with it.
This bonding plug is very controversial. Some say it's unsafe, others say the risk is minimal. All I can say is google the pros and cons and make your own decision.
