brulaz's avatar
brulaz
Promariner Pronautica chargers
Any experience here with these 120VAC charger converters?
Adjustable charging parameters and temp compensation.
http://www.promariner.com/en/63160
The manual is pretty good.
Google suggests they are not too expensive ...
  • DrewE's avatar
    DrewE
    Explorer III
    MEXICOWANDERER wrote:
    Gotta question - using the 60 example as an example
    60 x 3 = 180 amperes potential ?
    60 / 3 = 20 amperes potential?
    Can + outputs be ganged to multiply output?
    As I read it, 60A total, divvied up as needed among the three outputs (which might just be connectors in parallel and not really separate outputs; I didn't read the entire manual thoroughly). I think if you connect to just one of the three you get up to 60A there, no additional wiring required. At least their little installation schematics suggest that.
  • 60/3
    Other wise it would be listed as a 180 amp charger
    I suspect they can be ganged , so you could do one bank at 60
    Or split one bank 40 and second at 20
    The true charge 40, has two 20 amp outputs that work that way
  • Gotta question - using the 60 example as an example
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
