Old-Biscuit
Jan 15, 2014Explorer III
Think you just finally got gas flow up to the appliances.
5th wheel with propane cylinders do not have emergency shut-off solenoid activated by LP detector. LP detector is an alarm only.
Mounting a hitch on back of a 5th wheel to pull a jeep.
Frame may/may not be strong enough.
Then there is the overall length....65' MAX
Then there is the overall combo weight.....truck rated for that Gross combo?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
