joebedford wrote:
time2roll wrote:
joebedford wrote:
Where can you get really long pigtails? I figure mine needs to be about 10 feet.
10 feet might be custom made at a propane dealer.
Assuming this is on an RV you should also have two high-pressure regulators if connected by more than 5' away from the automatic regulator.
I went out and looked closely at it today. The hose from the street side is more like 8 feet long and there is a regulator on the street side tank in addition to the regulator on the switchover valve on the curb side. The longest pigtail I've see online is 60"
You don't need to replace the hose from the main regulator to the secondary regulator. Just replace the two short pigtails. One on each side from each regulator to the tank should only be about 12-15 inches long.
