RinconVTR wrote:
sato4000 wrote:
My RV dealer said he will fill up the propane 100 percent if you want.
Impossible.
For perspective...take a pressurized garden sprayer. Fill it to the brim, 100% filled. Then try to add air pressure and spray. You might get a drip of water, if your lucky.
Same principle here with LP tanks, but there are yet more reasons as to why 80% max fill is standard, and already mentioned.
The garden sprayer works nothing like your LP tank. With the garden sprayer, you need air that is compressible to store the pressure needed to push water out the hose.
LP boils at -44F so it wants to convert to gas and flow out of the hose, all by itself. There's no pressurized air helping to move the LP along.
The 80% is for thermal expansion.
