toedtoes
Oct 11, 2015Explorer III
It shouldn't be the 12v power that's an issue because it wouldn't work on 120v either AFAIK. You should check your propane lines and connections to the fridge - could be they were disconnected or damaged. Also check the thermocoupler.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
