John_Wayne
Oct 11, 2015Explorer II
You need 12volt for the control panel you may also have a blocked air fuel mixing tube (the large tube that goes to the burner area) also take an old tooth brush and clean off the top of the burner tube where the little slots are for the flame to come out. You may have to try lighting it a few times to purge the air out of the fuel line to the refrig.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
