DrewE
Oct 13, 2015Explorer III
Sounds like a typical lower-end Dometic fridge (such as the 2652) from the description of the exact buttons and lights. One power switch, one auto/gas switch. Auto in this case refers to switching between propane and AC when AC power is available; in the gas mode, it will run on propane regardless.
With a pushbutton switch panel, it definitely needs (12V) electricity to operate, as others have said.
Doemtic fridges (at least my model) also have a little manual gas shut-off valve in the burner tube assembly that obviously must be opened to operate in gas mode. It looks like a knurled screw, and rotates a quarter turn. With it closed but otherwise operating properly, the burner will try to ignite a few times and predictably fail, and the check light will then come on (maybe blink--I forget) to indicate a problem.
If the fridge has had fire recall work done on it, the added sheet metal cover must be removed to get at the gas shutoff valve. If the fridge is part of the recall but missing the work, I'd suggest making an appointment to get it done.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
