Old-Biscuit
Dec 15, 2016Explorer III
That heat outside is the exhaust from the combustion process AFTER it has flowed thru the heat exchanger that warms up the room air for inside heat.
RV furnaces are roughly 65% efficient in the transfer of heated combustion air to heated room air
When you think about it.....not bad for a 9" X 17" X 20" Box that has an air flow of 350 cfm or less and a propane system pressure of 0.4 psi
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
