Chris_Bryant
Dec 15, 2016Explorer II
IWally wrote:
Thanks everyone for your helpful explanations!Sam Spade wrote:
The heat going outside probable is normal. ALL vented heaters/furnaces work that way to some degree.
The "gentle" flow of heat inside, however, probably is NOT normal and may mean that your fan has failed.
@Sam .. I think you might be onto to something. It may be that a difference between forced air at the exterior vent and UN-forced air inside makes it more noticeable.
Merry Christmas!
They are both the same motor- one cannot fail without both failing, plus the sail switch is specifically meant to prevent this.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
