Boon_Docker
Dec 15, 2016Explorer III
IWally wrote:
Thanks everyone for your helpful explanations!Sam Spade wrote:
The heat going outside probable is normal. ALL vented heaters/furnaces work that way to some degree.
The "gentle" flow of heat inside, however, probably is NOT normal and may mean that your fan has failed.
@Sam .. I think you might be onto to something. It may be that a difference between forced air at the exterior vent and UN-forced air inside makes it more noticeable.
Merry Christmas!
If the fan has failed the sail switch would not operate properly and the furnace would shut down.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
