harold1946
Dec 15, 2016Explorer
Sam Spade wrote:IWally wrote:
At the vents the flow is a gentle convection of warm/hot air.
This can't be normal .. can it?
The heat going outside probable is normal. ALL vented heaters/furnaces work that way to some degree.
The "gentle" flow of heat inside, however, probably is NOT normal and may mean that your fan has failed.
There are two safety features on furnaces. A sail switch, which must engage, or the furnace shuts down.
An over temp sensor, which also shuts the furnace down.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
